DankTank
- May 26, 2017
- Reaction score
- 0
- Location
- Oklahoma
- Make / Model
- Ford
- Engine Size
- 2.9L
- Manual
- My credo
- If it ain't broke, fix it 'til it is...
So, I bought my 1986 Ranger XLT over half a year ago. in January, I had an engine from an '87 B2 installed by a reputable shop. Now I'm having 3 issues that are more than likely linked in some way.
First, the truck doesn't "kick off" in the traditional sense. More like it just "sustains" itself. It will kick off a little bit when it's cold, but nothing significant.
Second, the RPMs suddenly tank about a minute after starting, and unused gas blows out the tail pipe (The truck was straight piped by the previous owner, so no worries about failing cats). This is probably because there's no kick off to burn the excess gas.
Third, It's hard to start when warm. Like, really hard. Sometimes I have to give a big helping of throttle to get it going.
so far I have replaced the Ignition coil, and the Idle Air Control Valve. When I pulled the wire off the coil, the large pin came with it and I had to pull it out with some pliers. I've also tried seafoam and injector cleaner and that hasn't seemed to help either.
That's pretty much everything I can think of. At this point I might be replacing either the injectors or the distributor
