paulschmitz82
- Sep 2, 2022
- 0
- Germany
- Ford Ranger
Hi everyone,
i'm from germany and in january i bought a 1986 ranger (which is an import car), unfortunately it broke down couple weeks after i bought it, the reason was a broken crankshaft.
So i took it to a U.S Car workshop in germany (which are btw extremly rare) and the guy told me he will do an rebuild of the engine.
But after the rebuild the engine still doesn't want to start, and the guy closed the workshop, so i got back the car which is not running right now.
I actually figured out how to start the engine there are two possible options to do this.
1. you unscrew the valve on the fuel rail which is for presurre measuering, the engine immedieatly starts on the first crank if you do this
2. you open the throttle almost to the max and keep cranking for 30 seconds
otherwise the engine is not starting and the thing is it is running rich and i measured the injection times and while cranking the injection times are extremly high, if the engine is running the timing is perfect.
I also think the reason why it doesn't want to start is because it is running that rich and it's just too much fuel, but i also checked the pressure of the fuel pumps everything seems totally fine, the fuel pressure regulator also works fine.
Maybe anyone could give me a hint, which reasons there are that the engine could run rich?
