starter flywheel problems
tennesseboy
my fly wheel keeps getting chewed by the starter I have replaced it 4 times now and have ran out of ideas the shimming is fine of it is fine its like the teeth need to be bigger I cant understand how please help :icon_thumby:
forgey4x4
Washington
2.9l both
Is it a 2.9? I had the same problem with mine, I ended up putting a Ford escort starter gear on it, and haven't a problem since. Disregard, I didn't see 4.0l forum
Sent from my SCH-I545 using Tapatalk
downer
4
97 4.0 OHV 4x4
if you have a manual trans make sure you are not using an automatic starter as it may not fully disengage from the flywheel.
Also, make sure that if you are having chewing issues you replace the starter and flywheel together. If one is damaged it will take out the other.
