2.3L ('83-'97) Standard rings ?
Therigwelder
Mississippi
Ford ranger
I have my 2.3 block on the engine stand,ready for reassembly.I know the stock bore is 3.780, I also have a repair manual that calls out stock bore as 3.7795-- 3.7810. my current bore measured out at 3.775,I am needing input if I can go back with standard rings on my original pistons?
tomw
46
lima bean
vertical and above ground
If you have cleaned the cylinder walls, you should measure again. I doubt the diameter decreased below the lower limit or tolerance number.
Either way, unless you bore the cylinder over-size, the standard .010" or more, you would still use standard size rings.
It would be a 'good thing' to check the ring end gap of the two compression rings as you fit them to each cylinder. FoMoCo may specify a tolerance, but there is a formula for usable end-gap based on cylinder diameter.
Wiseco makes pistons, so should have a good handle on the measurement and spec:
tom
Fredness
28
Sasquatch Country!
Ford Sport Trac
4.0L SOHC
Metric vs. Standard...
Also, what are you measuring WITH, and where are you measuring?
If you are using a standard Dial Micrometer, it is difficult to get a good reading on a used block due to the ring ridge.
tomw
46
lima bean
If you are still undecided, put standard rings in. The piston crowns(top) would be stamped with numbers indicating if over-size pistons & rings had been installed.(such as 010 or 0202 or even 030 indicating a .010" overbore, etc).
tom
