Squeaky Suspension??
Ripplechip00Z
B-town, Manitoba, Canada
2.5L 4 cyl.
Alright so I've got a 1998 Ranger Splash 2wd with front coil springs. It has this annoying squeak in the front end when I drive down the road. When I bought it about 4 months ago the guy put in brand new suspension as it was previously slammed. I've had it up on a lift and looked at everything but haven't been able to spot the culprit.
Could it be something other than suspension or am I just blind?
srteach
9
Ranger, F350
4.0L, 7.3 Diesel
Cab bushings can be squeaky, and there are 6 of them. Check the rubber to see if it is excessively soft or bulged out. Polyurethane rubber bushing replacements are fairly inexpensive, actually cheaper than Ford rubber replacements.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
ball joints?
Ripplechip00Z
2.5L 4 cyl.
ball joints should be a part of the new suspension but it can never hurt to re-check. Also the sway bar. Hmmm don't remember what it looked like.
I have no idea where to looks for cab bushings. Or what they look like.
Thanks!
4.0B2
151
Walls, MS
4.0 v6
Between the body and frame. Its the bushings the body sits on and the body bolts go thru the body bushing. Also the same place that the body lift goes if you do a body lift
Ripplechip00Z
2.5L 4 cyl.
Ok I'm gunna try and get it up on a hoist again today and take a look
sloue
Canada
302
rad arm bushings spray them down with some wd 40 and take it for a drive . bet thats it when i did mine they made all kinds of noises. i put a bit of grease in there no more noise
YZ250Rider23
2.5
Sloue, there is no radius arms on the 98's.
Tie rods, ball joints, or sway bar bushings and links. They can all make a squeaky squeak noise.
The ball joints can be tricky to diagnose. All of mine appeared tight but once you pushed or pulled at the joint with a prybar, you could see play.
sloue
Canada
302
well i should have read that closer . man iam slow. well if it had r arms thats what i would do . best thing to do is to swap in a ttb that way you can grease up those r arms and stop that dame noise
Brian.Smith
I had a squeak like that!! Drove me CRAZY. Turned out to be the cab bushings/rubber mounts. I sprayed the hell out of the with PB blaster since they were intact. Problem solved!!
Kirby N.
March Truck of The Month
