Squeaking Noise Inside Cab
JW20
6
Somewhere
Hey guys, I've got a 97 XLT long cab/bed that has developed the most horrendous sound inside the cab. It's coming from somewhere on the passenger side and I cannot reliably reproduce the sound, or determine where exactly it's coming from. It sounds like maybe it's coming from the passenger door, pillar, or glovebox area. I've removed the pillar, door panel, glove box, and done everything I can to figure out what the noise is. It sounds like two pieces of styrofoam or plastic rubbing together and it's loud. It's way more than just a rattle because even with music playing and the window down, I can still hear it over everything. I even took a rubber mallet and went around trying to see if I could recreate the sound; no luck.
Any ideas?
Uncle Gump
Token Old Guy
13,423
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
HVAC blower fan rubbing. Next time you hear it... change blower speeds and see if the noise changes.
superj
2,554
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
/\ good answer.
pjtoledo
2,951
Toledo Ohio
Fords
3.0 2.3
going to need some creativity
sit in the pass seat with a flexible hose of several feet length
one end in your ear, move the other around until it gets louder
and whatever uncle gump says
JW20
6
Somewhere
I thought that was it for sure so that was the first thing I did. No change; it does it regardless of whether the fan is on or not. I also thought maybe it was the fresh air louver but it's not that either.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,533
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Do you have a four door supercab? Sometimes the latch bars wear and cause squeak issues.
JW20
6
Somewhere
I wish. It's just the two-door version. I think I might have someone else drive the truck so I can sit in the passenger seat and figure out what the heck is making that sound. Just gotta find somebody that can drive standard.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Take a look around the door and the jamb for any rubbed/scraped paint. The hardest squeak to find is a broken spot weld. So, knowing how to recreate the squeak will sure make it easier.
scotts90ranger
4,309
Dayton Oregon
2.3 Turbo
Try taking the door panel off, my drivers side door makes a horrible noise at times when driving... I went to the extent of putting duct tape on the metal side of all the contact points, since the panels aren't really held securely with the what, 4 screws? they're somewhat wobbly... it got better when I replaced a broken screw section with a washer for more support...
JW20
6
Somewhere
Thanks for tall the suggestions everyone. I had someone drive the truck and I opened the passenger door when it started and it seemed to stop. I had the panel off previously trying to diagnose the issue and could not find the noise. Next step is to lube the door seals and check for spots where it might be rubbing. The passenger door rarely gets used and sometimes has to be yanked open, so I have a feeling that has something to do with it.
