Zmiller0218
- May 6, 2022
- Reaction score
- 0
- Location
- Athens Georgia
- Make / Model
- Ford ranger
- Manual
Recently purchased it, I’ve replaced just about everything I can think of. Plugs, wires, cap and rotor button, map sensor, fpr, ignition coil, is it ion module, fuel filter, cleaned fuel injectors, took cats off and ran it still does it. It’ll run and idle fine for the must part sometimes it does surge at idle, my main issue though is when going down the road in lower rpm’s it’ll spit and sputter like a misfire just about in every gear and puff out clouds of smoke, I can floor it and it clears up and also sometimes coming to a stop it’ll die. My only guess is either the fuel pump in tank or the high pressure fuel pump on the rail. Anyone else have a opinion or had a similar issue? Just tired of throwing parts at it and it still not running right.
