Spring rate vs Load rating?
BrownRangers
49
Burbank, CA
2.8 V6
171cui
3"
Does anyone know the spring rate of the 1050lb(load rating) rear leaf springs and/or the 1350lb.
Spring rate would be more in the 200-300 lbs I would assume.
I was going to try to fit some fiberglass leaf springs from a different application into my truck. Thinking I might want to get some air bags to assist if I end up still using it as a truck.
Thanks for any input.
55trucker
183
Oshawa, Ontario
mild
Removed from the vehicle spring rate is the mount of downward pressure applied to the centre of the leaf spring assembly to compress it 1 inch.
To find out what yours are you would have to find a spring shop that actually has a leaf spring spring rate tester, not many do.
pjtoledo
2,964
Toledo Ohio
Fords
3.0 2.3
"hold my beer" method of determining spring rate.
place jackstands under rear axle, you want to measure springs not tires.
accurately measure fender to ground on both sides.
have a 200 lb buddy stand directly over rear axle, bounce & settle then measure
remember that's only 100 lbs per spring
2 buddys, 3 buddys , or anything you can weight accurately.
it's a slow night :icon_thumby:
don4331
1,346
Calgary, AB
5.3
Where did we find this crew?! :LOL:
'86 - '03 Ranger 1,100 lb spring 2 leaves + overload, 323lb/inch
'86 - '03 Ranger 1,250 lb spring 3 leaves + overload, 417lb/inch
'03 - '11 Ranger 1,110 lb spring 2 leaves + overload, 370lb/inch
'03 - '11 Ranger 1,250 lb spring 3 leaves + overload, 408lb/inch
'03 - '11 Ranger 1,350 lb spring 3 leaves + overload, 617lb/inch
Aftermarket 1,750 lb spring 4 leaves + overload, 636lb/inch
'91 - '01 Explorer 1,110 lb spring 3 leaves + overload, 338lb/inch
'91 - '01 Explorer 1,250 lb spring 3 leaves + overload, 519lb/inch
superj
2,574
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
i guess you have to look at the door sticker to see which 3 leaf pack you have to know if you are the 408 or the 617 numbers, on the 03-11 range
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
I was shopping for leaf springs, and rock auto and one other site (I think james duff) actually provided specs like load rate, spring rate, #of leafs, and even free arch as well. I noticed some of the same load rate springs came in different size free archs. Hope his helps.
BrownRangers
49
Burbank, CA
2.8 V6
171cui
3"
Stock my truck is a 1984 Ranger S trim. What I am finding is 1050lb load rating. I have drop -1.5” shackles with 1250lb springs from a ranger edge which are +1”. I am going to be trying some Hyperco Composite 225lb spring rate 4.5” arch(-2” compared to ranger) springs @875lb load rating for road racing style track days. Won’t be putting anything in the truck bed for hauling except for what tools/wheels/spares/jacks are need for the track days and bikes.
Link:
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
I have 1050 lb springs. Hauling a dirt bike and its gear is no problem. It rides nice empty too. I once drove a drunk friend home back there, cab was full. He said it was the smoothest laying in the bed of a truck ride home he's ever had. I am happy with them.
racsan
4,440
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
I have the single-leaf fiberglass rear springs, which is odd since its a reg cab longbed. 320# of softner salt really squats it good. I have axle mounted coil helpers but took them off recently so my backroad morning commute wouldn’t be such a rough ride.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Nice, ever haul a drunk buddy home on those? looks smooth....
superj
2,574
ranger edge
none
none
235s
until this thread, i didn't even know single leaf springs existed
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
I think they were available on the 2 door Explorer Sport models
