100Timelord
- May 10, 2021
- 4
- Waukesha, WI
- Ford Ranger
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 2WD
97 Ford Ranger (72k miles), RWD W/ Rear ABS only
Alright, I just changed out the front rotors, pads, and bearings. Plus some odds and ends that had worn out. Small change, I know, but it's the first brake work (or major fix in general) I've ever done, so it's big fish for me, capeesh?
Anyhow, doing so did fix the steering wheel shaking during braking, improved the stopping power, and (I think?) got rid of a squeak (and 'bearing sound') coming from the front left.
However, it did not fix a spongey feeling and "air sound" from the brake pedal at the end of it's travel. I cracked the master cylinder when I compressed the caliper pistons, and I noticed A LOT of fluid overflowing. Is this normal on a front brake replacement? It was almost as if someone had seen the fluid was low, so filled it instead of servicing the brakes (I bought the truck 2 weeks ago).
What I'm asking is, is this behavior normal, or do I need a brake bleed or something else? I think the rear drums are in poor shape, as the parking brake does not hold the truck stationary when in park, and though I feel them drag, I don't feel much pull from the rear when braking. Of course, maybe this is normal/a different issue so input on the rear drums would also be useful.
Thanks, and Godspeed
