Spindle and shackle lift
NCHammer
Knoxville, TN
Ford Ranger XLT
I'm replacing the spindles in the front of my RWD to give it 4", changing out shackles in the back to give it 2" in the rear. A couple questions, probably dumb, 1) do I need to buy shocks for the rear; 2) should I AAL while I install the new leaf spring shackle with 2" lift or replace the leaf spring assembly; and 3) can I add 1.5" blocks to the rear as well?
Thanks y'all
RustyShackleford94
Just some guy
355
IN
1) Probably, youll be near maxing out your stock shock with a 2 inch lift. Definitely if you AAL and a 1.5” block with the shackle.
2) If you haul stuff often then it wouldnt be a bad idea.
3) I don’t see why not.
NCHammer
Knoxville, TN
Ford Ranger XLT
is my best luck looking on ebay or stick to sites like summit?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
With an extra leaf, 1.5" blocks, AND 2" shackles you will be at 4 - 4.5" of lift in the rear. Yes you will need new shocks. An extra leaf will make the truck ride stiffer so can't say I'd recommend that unless you are frequently hauling/towing alot.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
