Out of curiosity, does anybody have specs for the OEM stock inline fuel filter on a Ford EFI system?
I spent a few minutes looking through a few Ford manuals and drew a blank.
So I checked replacement fuel filters on RockAuto for the three EFI trucks I have (1990 & 1994), and the Motorcraft replacements (two models) included this info:
" . . . withstand up to six times normal operating pressure . . . Capture 98% of particles as small as 8 microns".
The other aftermarket brands, the few which listed any specs, all were rated at 10 micons.
So . . . does anybody have the Ford specs? Or, if someone wants to convert their truck to a spin-on, what specs would be reasonable?
#1 Particle filtration size rating - no larger than 10 micron?
#2 Max operating pressure rating - I think an EFI system reaches about 40PSI maximum; so what would a reasonable max pressure rating for replacement hardware?
# Flow rate - I think I saw an aftermarket replacement list "1 GPM" as a flow rate spec (seems low?). Otherwise, I have no idea what a desired minimum flow rate would be.
Granted, converting to a spin-on would likely get you a slightly larger filter and perhaps larger fuel line fitting sizes, so I suspect that flow rate wouldn't be an issue. The max pressure, however, seems kind of important- a fuel leak can be a major bummer, and lead to having a REALLY bad day.
Thoughts, anyone?
