Is it the speedo head thats making noise or the cable Iam betting the cables bad and winding its self up in the out housing, I dont know on your year if you can pull the inner cable out form the bottom and grease it but it will only take a few minutes to pull it and see
Yes, '94 still used a mechanical cable from trans to dash.
One of the strands in the cable has broken, so it binds then releases, causing the jumping of the needle.
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
