Speedometer gear, bigger tires
9
Albuquerque New Mexico
3.0L V6
Stock
Stock 225/70R15
Does anyone have an Automatic ranger from 98-00 that came stock with the 245/75r16 wheels? I’d thought it’d be much easier if someone had the speedometer gear to show me so that I could just buy the same to go to the bigger rims and tires. And assuming the 3.0’s and 4.0’s have the same transmission meaning the speedometer gears would be the same, but if they’re not, specifically for a 3.0 automatic with 245’s. Or screw all that stuff and if someone has already done the silly math to find the new speedometer gear for an automatic for 31’s that’d be fantastic.
Rock Auto 5% Discount Code: 81874766E40C6A 5th, 2022
Dirtman
13,294
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
There is no gear, it's a VSS. You change the speed/tire setting via the computer. You can do it with forscan or a tune shop.
sgtsandman
Aircraft Fuel Tank Diver
Forum Moderator
4,713
Aliquippa, PA
Ford Ranger XLT
4.0 SOHC
Pre-2008 lift
31X10.5R15
What Dirtman said, ‘98+ doesn’t use gears for the speedometer.
