Spark plug wires very stuck on spark plugs - 1996 4.0
sebastian323
24
Merced, CA, USA
Ranger XLT
The spark plug wires are VERY stuck on to the plugs on my 1996 XLT. The truck came from Montana so there is moderate rust on a lot of the engine parts not typical of California cars. Is there some way to break/cut the wires off ? I have only managed to change one spark plug so far
8,369
Just twist them and/or take a long blade razor knife to cut the boot and then use a screwdriver to open it up
Picture of boot extractor here: https://m.media-amazon.com/images/I/51a1FITDr9L._AC_SL1164_.jpg
You can probably make a version of this for temporary use, basically you pull up on the boot from the bottom so it doesn't squeeze tighter when pulling from the end
The rubber boots are like the Chinese finger puzzles, the harder you pull from the top the tighter they get
gaz
654
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
@sebastian323 ,
I recommend using some dielectric grease on the insulators when you put the plugs in.
