therabbithole
- Jan 10, 2020
- 1
- Salisbury, MD
- Ford Ranger
Hi,
I have a 1987 Ranger that won't start after I myself drove it - under its own power - into the unheated, northeastern garage bay where it sat for about the last 20 years. Following is what I've already done and checked: it seems like it has both fuel and spark, and cranks really well, but doesn't sneeze or cough or really even seem to think about starting so I'm here for advice on what to do or check next. Please?
I'm grateful for any ideas or advice anyone can share; my best sense is that because I can't attribute the dead warning lights to a bad ground - either for themselves in the dash or for the computer itself - that I need a new computer. I know enough not to trust my own 'best sense', though, so... what else can I test or check? Thanks in advance!
1. dash / warning lights: parking brake / low brake fluid light works, but warning lights with smaller bulbs on PCB (4x4, LO-RANGE, EMISS) do not illuminate (checked bulbs and confirmed shared ground with rest of instrument panel)
2. wiring
a. brand new battery, clean/tight battery cable terminals, clean ground from battery negative to radiator support, and jumper ground from battery negative to computer ground at passenger kick panel
b. harness hot with ignition on for MAP, IAC, and TPS
c. IAC 10.1 ohms between terminals & ~4,000 ohms either terminal to housing
3. ignition: confirmed spark with timing light on coil & plug wires while cranking; distributor has not been moved
4. fuel:
a. all old gas drained, brand new gas and fuel filters
b. fuel pump cycling audibly when ignition switched to run, and observable pressure at fuel rail test port
c. injector harness hot with ignition on, and ground pulsing on both wires while cranking
