No, but, most people would tell you to by pass the RABS. I have never had the module fail, just the valve which just needed a good cleaning on the inlet screen. If you removed the board and took high quality pictures of both sides it might be possible to determine what failed, if you post the pictures. I use to repair old Commodore and Apple computers, leaking or blown capacitors are an issue and I had one power supply give up the smoke just from one bad resistor. I doubt the RABS has any sort of CPU, so, just replacing all the components might work. They did not use SMT back then, so, it is going to be easier to fix then on a newer vehicle.
