Source for '89 Bronco ii ABS Control Module
dfreise
Topeka, KS
2.9 L
Anyone know of a source for a replacement control module? Upfix does not do repair work on this model. TIA for any help of suggestions.
4x4prepper
192
Atlanta
No, but, most people would tell you to by pass the RABS. I have never had the module fail, just the valve which just needed a good cleaning on the inlet screen. If you removed the board and took high quality pictures of both sides it might be possible to determine what failed, if you post the pictures. I use to repair old Commodore and Apple computers, leaking or blown capacitors are an issue and I had one power supply give up the smoke just from one bad resistor. I doubt the RABS has any sort of CPU, so, just replacing all the components might work. They did not use SMT back then, so, it is going to be easier to fix then on a newer vehicle.
dfreise
Topeka, KS
2.9 L
Thank you. I will be investigating more when the weather warms up.
broncc
280
MA, USA
Ford Bronco II
Giving my truck more money than it deserves.
Here is a link where I post the full RABS diagnosis guide. I would check rockauto for the control box or the dump solenoids.
