A4LD_Nghtme
- Nov 7, 2021
- 47
- Twin Bridges, CA
- Bronco II XLT 4
Hello! I swapped out my 4x4 transfer case motor on my 1990 Bronco II XLT and I now have no lights at the dash at all and zero control module actuation. Before the swap the lights would come on for both 4 Hi and 4 Lo and the you could hear the 4x4 control module function. Now there is zero anything after the brand new motor swap.
I have ran the following tests from https://www.therangerstation.com/tech/ford-ranger-4x4-module-diagnosis-1994-older/
As follows here were my results and I still have zero lights, control module actuation and of course zero engagement.
Diagnostics:
Step 1.
Fuses are good. Pass
Step 2.
4x4 module clicked and flashed. Pass
Step 3.
a. Test between terminals 1 and 2. Pass
b. Test between terminals 1 and 3. Pass
c. Terminal 4 and ground. Pass
d. Terminal 5 and ground. Pass
NOW HERE IS WHERE IT GETS MESSY FOR ME TEST-WISE!!!
Step 4. The next step will check the circuitry to the shift motor. Your shift motor must be hooked up for this to work. Grab the 8 wire connector that is unplugged from the 4×4 module. It will be tan in color. Check the following:
a. Test between terminal 1 and ground. Pass
b. Test between terminals 2 and 3. Pass
c. Test between terminal 8 and 4 = 0 ohms, test between 8 and 5 = 0 ohms, test between 8 and 6 = 0 ohms and test between 8 and 7 is zero ohms. I am not getting high resistance in 7 nor 5 like I should. This test states to "connect an ohmmeter between terminal 8 (yellow/white) and terminals 4 (violet), 5 (white), 6 (brown/white) and 7 (orange/white), respectively. Refer to the following chart for the appropriate ohmmeter readings in each transfer case position."
Step 5. Up to now, the following should have been verified:
a. You verified that:
YES 1) All fuses are good.
YES 2) The 4×4 module tested ok, and has power/ground (make sure the pigtail connector isn’t corroded – is common among rust belt trucks)
YES 3) The 4×4 switch tested ok.
Partial YES 4) The shift motor circuitry tested ok. (FAILED TO GET CORRECT RESISTANCE READINGS BETWEEN TERMINALS 8 AND 4, 5, 6 AND 7. although 4 and 6 should be short or zero ohms)
Now I was iffy about continuing the test after failing part C of step 4 but I trudged on for more information.
NEXT
Back probe the solid orange wire through the connector located on the shift motor side. You are essentially checking for voltage at this pin to ensure that it is getting voltage, and that the connector is good. Next, turn the key to run and push the 4×4 switch. You should see 12 volts on the volt meter. If not, ensure that the volt meter has a good ground and try again. TEST FAILED. 0 Volts detected(after multiple probing and changing grounds for better grounding)
2) If you’ve got nothing still, go to step 6.
And I kind of lost hope at that point.
Does anyone have an idea what could be occurring. She is a great RWD vehicle but I hate having all that extra weight from a front diff that doesn't get used at all. Thabk You so much for any information.
Diagnostics:
Step 1.
Step 2.
Step 3.
NEXT
