For Sale SOCAL 1st GEN parts MSD, Holley, Motorcraft, Block/Heads cores, I-beams and more
BrownRangers
49
Burbank, CA
2.8 V6
171cui
3"
I have a bunch of items from 1983-97 Rangers I will posting up and trying to get out of my garage. Will ship some smaller parts but will not ship some things at this time like i-beams and rear window as an example. I will be updating this as I go thru all my parts. Prefer local pickup, can meet-up with reason. I am in Burbank area and go out to Rancho Cucamonga often.
1983-1988, 1989-1992 1989-1997 and some universal parts:
Most parts are for 2.8 and 2.9 application, please check your cross references
Most suspension parts are for 2wd application
1984 V6 non a/c steel radiator removed for upgrade was still working and not leaking
1983-1992 Spare tire carrier and spare wheel/tire tire is going bad
1984 2.8 clutch master, slave and line to fit the TK5 trans all BRAND NEW in box
1983-1992 Rear window with slider, this is an early silver aluminum trimmed window, latch works glass no cracks and rubber gasket all in good shape, no shipping
Bellhousing with clutch fork for a T-5 trans to a 2.0 block.
Front posi-quiet brake pads fit my 1984 single piston caliper pin mount type caliper fits up to 1994
KYB Gas a Just front shocks, used for about 5-6k miles still feel good, have new rubber bushings to go with them
Power steering pump, pulley, bracket, belt and new lines from a 1988 2.9(should fit 2.8 and many others)
1984 Motorcraft 2150 2bbl stock feedback Carb, TPS removed but can include, thought mine was bad swapped it but that wasnt the issue, never re-installed
SOLD I have a core engine 83-86 2.8 disassembled standard bore block,loaded with springs and valves heads,pistons/rods,intake,intake carb spacer,standard crank, lots of little bits SOLD
SOLD
Holley 2bbl 2150 carb, 350cfm for Duraspark swap or run instead of feedback carb, been sitting, could use a rebuild, I can rebuild if you need but will charge for service. SOLD
1994-2004 Mustang Cobra rear calipers only, NO brackets, backing plates, anti moan, pads, lines or dust shields, just the calipers themselves, in good shape
Steering stabilizer/damper brackets (for non front mounted sway bars) and seems worn out cylinder, replacement cylinders available from rockauto
Clutch and flywheel stock oem style NEW but been sitting so doesnt look so pretty will get brand off the clutch think its stamped somewhere when I pull it out next
1988 2.9 V6 TFI style distributor, cap, rotor with set of wires. Working when removed, parts cross reference to the 2.8 so should work just fine. Can include a TFI module its currently in my glove box as a spare.
1988 darker tan sunvisors
MSD Blaster 2 canister style coil
MSD SS blaster PN#8206 style coil
1989-1992 2wd front Radius arms
1988 2.9 transmission cross-member with the outrigger style bushings, have the frame sections still attached since I cut the frame out about 6 inches in front and back of the cross member
1983-1992 light tan doors with glass, internals regulators/lock/handles/window cranks/hinges, right is straight, left has slight crease/imperfection, doors are solid, internal panels are trash, no mirrors. They have been sitting outside so rubbers need replaced. Pickup only.
1983-1988(maybe 1989-1992) hood latch set, upper and lower latches
SOLD MotorCraft Duraspark II 3 wire V6 distributor with large cap adaptor vacumn advance, rotor and large cap included, working when removed, cosmetically could use a clean up, needs new harness connector or not, will work either way SOLD
Square Halogen headlights, pair, basic, say Halogen dont know much more.
1983-1988 dash speaker covers
Sealed bag of drum brake hardware, springs, adjusters, I just did my 9" then upgraded to 10" so didnt even open the bag of 10" hardware, its the full kit of everything from the Carlson brand, PN# H2335 but its just the bag of hardware/springs/adjusters,cables and such
1989-1997 stock I-beams you can upgrade to larger brakes with 95-97 spindles with these.
I will ad some initial pricing once I have more time.
I will have a running 2.8 v6 after my swap and other things with lots of recent parts replacements. The 2.8 v6 in my truck now has a new power steering pump, water pump, belts, fuel pump, rebuilt carb, spark plugs, wires, rotor, cap, k and n 10" filter, recent valve cover gaskets and many other small service parts. I was taking it to the track a couple times so all services where done at very often intervals. Have it setup with an MSD 6AL ignition box with the TFI MSD adaptor harness and an upgraded Accell coil. Engine could be sold from Air Filter to oil pan complete.
Things I am looking for:
1983-1988 good condition A/C box, controls and components. I have non-A/C heater box and controls for trade if needed. Locals prefered due to size.
1995-2001 Mustang rear caliper BRACKETS from v6, non Cobra
2.8 Bellhousing to T-5 trans from Capri, Mustang II
90-92 8.8 rear axle code R5
Bronco II rear axle 7.5 code D2
Ranger rear axle 7.5 code F5
Please check what things sell for on ebay for current selling prices but make me some offers, remember shipping has gotten more expensive lately. Pickup prefered
THIS WILL BE AN ONGOING THREAD AS I SWAP AND UPGRADE MY RANGER
BrownRangers
49
Burbank, CA
2.8 V6
171cui
3"
Big Update, will be adding more stuff. DM for more info or pics of particular items.
Bronco648
86
Chicago-land, Illinois
XL
2.3
15"
MotorCraft Duraspark II 3 wire V6 distributor with large cap adaptor vacumn advance, rotor and large cap included, working when removed, cosmetically could use a clean up, needs new harness connector or not, will work either way.
How much and will you ship it (to Chicago)?
I can create the shipping label and email it to you (as long as you provide the weight of the box). All you would need to do is print the label, affix it to the box and drop it off at UPS (or give the box to a driver, supposedly).
Sorry, I have nothing to offer you in trade unless you're interested in a 2"/3" lowering kit and lowering shocks (all NIB). I also have an Edelbrock dual plane manifold.
LMK, thanks!
BrownRangers
49
Burbank, CA
2.8 V6
171cui
3"
Updated and bump.
Angie
365
Vancouver area BC Canada
92 & 83 project
4.0L 302
still want to trade? i just seeking the box, don't need the fan or controls. if you want to swap boxes.
sexybluelady
8
springfield, ma
ford, mitsu, do
2.9
Would you sell a coolant tank cap and a passenger side wiper linkage if the bushings are still good in it.
BrownRangers
49
Burbank, CA
2.8 V6
171cui
3"
DM me, would like to know how much of the a/c setup you might have to go with it. Sorry for late reply.
Don't have these items. Not listed.
TexasDuck66
9
Cleveland Tennessee
Do you have a TK5 shifter assembly?
BrownRangers
49
Burbank, CA
2.8 V6
171cui
3"
I have an original but it is quite worn out. I might be selling the Core shifter with the Hurst shifter shaft if I end up upgrading my trans. That might be a few months tho.
Angie
365
92 & 83 project
4.0L 302
hi, found a box local. it had complete 2.8 A/C system.
BrownRangers
49
Burbank, CA
2.8 V6
171cui
3"
All updated, DM sent and requests replied to and answered.
brett387
Florida
ford ranger
2.8 V6
3 inch body lift
Whats the venturi size for the motorcraft 2150 if you still have it? Thanks
BrownRangers
49
Burbank, CA
2.8 V6
171cui
3"
I believe it is a stock 1984 carb. What ever those were. I’d have to dig it out to measure. I’d take $50 shipped if you want it.
brett387
Florida
ford ranger
2.8 V6
3 inch body lift
If you could check what size it is, that would be awesome. I got 1.21 venturis on my 2.8 engine, and its not running great with it. If its got 1.08 venturis in it, ill glady buy it. Also. Out of curiosity, how much would it cost if you were to rebuild it? Thanks
JerrySab
27
Los Angeles
Hey guy!
You wouldn’t happen to have a wiper lever would you?
Carlisle Truck Nationals
Join us at the Carlisle Truck Nationals for the 40th Anniversary of the Ford Ranger.
