So i need some help.
Schwinnstingray1964
Ranger XLT
2.3 4Cyl
About a Year ago, The clutch pedal on my 92 had sunk all the way to floor.
I put in a new master cylinder, and the pedal came back up.
1st question, The hose that goes to the slave, Is it supposed to have an o-ring on it? Does anyone have a picture of said o-ring.
2nd question, Where is the bleeder valve on the trans.
3rd question, How hard is this whole bleeding thing to do? Would i be better off sending it to the shop for bleeding?
-Thanks. Schwinny. :icon_thumby:
Schwinnstingray1964
Ranger XLT
2.3 4Cyl
Bump Bump Bump, Thats the sound of the 15's while they're hitting in the trunk...
kennykenny
4
Manahawkin, NJ
There is supposed to be an o-ring on the transmission end of that hose. I can't remember if there was one on the master cyl. side. The bleeder is right above that hose on the side of the transmission coming through the bellhousing. And for you're last question bleeding it can be a pain but if you do a quick search on it you'll find all the information you need.
Schwinnstingray1964
Ranger XLT
2.3 4Cyl
Thats a cool video, Do i have to drop my tranny in order to bench bleed?
Cause that would definatly be cool, if i could do it this easy.
How about reverse bleeding? Pumping fluid through the bleeder valve.
piotrsko
reno
11" KOSTOV 192V
the problem is at the master cyl and the annoying air bubbles that live at the end of the piston therein. I haven't seen a lot of success with pressure reverse bleeding.
kennykenny
4
Manahawkin, NJ
Take the master cyl off the firewall and turn it upside down while bleeding to get that air out.
Schwinnstingray1964
Ranger XLT
2.3 4Cyl
I was gonna bench bleed.
How do i get the hose off the slave? Do i have to drop my tranny, Please say no.
kennykenny
4
Manahawkin, NJ
There is a special tool to take the hose off the slave. You should be able to get it at any parts store for only a few dollars. Looks like this:
Schwinnstingray1964
Ranger XLT
2.3 4Cyl
Sweet, Is the slave hookup in the trans or on the outside? I havent even looked yet, Its been to wet out to get under my truck.
kennykenny
4
Manahawkin, NJ
The connection comes through the bell housing so it's all done from the outside, no need to remove anything.
Schwinnstingray1964
Ranger XLT
2.3 4Cyl
YES!
Thanks for the help.
Feedback given.
kennykenny
4
Manahawkin, NJ
No problem, that's what this site is here for.
Kirby N.
March Truck of The Month
