Snow!
lil_Blue_Ford
6,129
Butler, PA, USSA
4.9L
We got some snow but it’s long gone. I had no need to be out in it. Can’t really drive right now and most of the trucks are presently broken anyway
1990RangerinSK
1,312
Saskatchewan, Canada
We were supposed to get 2" or so but ended up getting about six on Saturday. My son got a snowmobile this fall and he was able to ride it, so that's good. I actually like the snow. It allows for lots of activities I cannot do in the summer, like snowshoeing, snowmobiling, etc. That said, I don't like when it's teens+ below zero, for weeks on end. Especially if there's no snow. I think having drastically different, but short seasons helps one appreciate each one a little more.
You would love Saskatchewan, then. We do have four distinct seasons. Winter is cold and snowy. Spring is warming up, and full of new life. Summer is hot and sunny, with lots to do and see. Fall is colourful, as things cool down in the lead-up to winter.
racsan
4,441
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
snowing again here, big flakes. No wind either. for the first time in many days the windmill isn’t turning. Have less than 1/2 inch. Would be a good christmas eve snow. Watch- christmas it will be 45 and rainy I bet. I used to love the challenge of snow driving, powersliding around corners & spinning tires through the first 4 gears of a 5 speed. Now I just want it for christmas & it can stay away for the rest. But that’s mostly due to sliding sideways off the road 2 years ago at 2 am and winding up facing the opposite direction I came from and on the side at that. The real kicker is that I wasn’t goofing off at the time, the butt of the car just went to the right & I couldnt bring it out of the slide, Shoulda turned the wheel left & floored it I guess.
Oh look- deere tracks! :
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,641
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
It’s too early for this crap. We normally don’t get these temps and snow before Thanksgiving.
I still need to put the carport up yet and I’m scrambling to get the trailer finished so I can clean up the garage and get the trailer parked for the winter.
So, I’ve been using the kerosene and electric heaters in the garage so it’s warm enough for the paint and primer to cure. At $3.64 a gallon and price of electricity going up, it’s getting expensive fast.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I bought a propane torpedo heater last year... maybe two years ago. That thing is no fuel miser.
It should heat up my tiny garage pretty quick though.
sgtsandman
Ham Radio Operator
12,641
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Oh, it heats things up fast for sure and it doesn’t take long to burn through a 20# bottle. It also sets the CO monitor off.
I use it to heat up the garage quick and then use the kerosene heaters to maintain temp and keep the edge off the chill from the still cold concrete floor.
It’s also great for quick jobs out in the driveway. Put the vehicle up on ramps and point the torpedo heater underneath. It helps keep the chill away.
Roert42
4,959
Kintersville, PA
Ranger XLT
4.0 SOHC
I picked up a torpedo heater last winter. My wick kerosene heaters kept getting gummed up I assume from water in the kero. Torpedo doesn’t care, clean plug every couple days.
Use the radiant propane heater after the kero torpedo gets the garage toasty.
racsan
4,441
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
I bought a used torpedo heater for $20 at a garage sale over the summer, no idea if it works, about to find out soon!
black_demon69
142
AZ
4.0l
I havent seen snow in almost 10 years since moving to Arizona, and I don't miss it. Heck I am still wearing shorts and sandles.
ekrampitzjr
1,067
Virginia
I've got years of experience with kerosene heaters. The wick problem is probably from old kero from wherever you're buying it. I learned from experience to buy kero only from fuel stations with an underground tank. The stations with above-ground tanks by the kero pump have more problems with fuel going stale because the tank is exposed to summer sun and temperature extremes.
It doesn't take much stale kero mixed with fresh to gum up a wick. Once the wick is like that, instead of trying to burn off the gum, you're better off replacing it. Use fresh kero with a new wick.
Also check where people who use a lot of kero are getting theirs.
Water in otherwise good kero will cause sputtering during burning. It doesn't gum up a wick so much as tear it up.
Chapap
672
NW Florida
Ford Ranger XLT
2.3
1.5” till I get these springs replaced
225-70-R14
I had to dig out the jacket this morning. Pretty soon I’ll have to swap to long sleeve shirts. I wouldn’t mind spending a winter up north. I sometimes feel left out not knowing about snow chains and shovels and such. It’s funny to me that power tools exist to deal with weather.
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
Use clear kero not dyed could be related to wick problem maybe.
1990RangerinSK
1,312
I'll just leave this right here.
<iframe width="560" height="315" src="
" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
I'll give you the rundown..
Chains are a pain in the ass, a dedicated set of winter wheels/tires is the way to go. Put em on in late November, take em off in late may.
Shoveling can go to hell. Having a blower that can fit between the railings on your front porch is a must lol.
If your an individual who's capable of piloting your vehicle through a snowstorm like nothings even going on.... having to drive anywhere when it's snowing is the most aggravating thing ever. It doesn't take long to get stuck behind a subaru doing 20mph down a 50mph road because there's a dusting of dry fluffy snow on the pavement.
The treatments they dump/spray on the roads to keep them from freezing will eat through steel like nobody's business. It's estimated that BILLIONS of dollars are spent every year in the rust belt on rust repair. It's so bad that politicians have suggested that people who live in the rust belt should be given a tax credit for having a vehicle that dissolves every time you drive it for 4-5 months of the year.
Hearing people complain about having to drive to work when it's snowing is absolutely maddening. I'm sorry... but... it's not even remotely practical to shut everything down just because it's snowing. These people will complain about having to drive into work when it's snowing, but would raise holy hell if they stopped by dunkin donuts on their way home and couldn't get a coffee because theyre shut due to weather. MOVE TO FLORIDA ALREADY!!!!
bilbo
922
South Florida
2.3L
Yes. I have a couple of choices for my commute to work. Freeway, county highway, or gravel. Gravel is usually out in a bad snowstorm because it gets to the point where you cannot tell where the road is anymore. The freeway is where all of the crazies are, and usually looks like the scene of one of those apocolyptic natural disaster movies, forget that. So usually it's the county highway and there's always that 20mph car. Always. And naturally no good way to pass them.
I remember in the mountains in WA there being signs that said if you had more than X cars behind you, you're required to pull over and let them pass. We need something like that here.
