Smoke coming from hazard button !!!!!!!
cauhcons
Quebec City - Canada
Mazda
Hello, i have a B4000 99 and some time when i put key on power position, in the cluster the left arrow stay on and a little smoke is coming out from the steering column throw the hazard button, once the smoke stop the left arrow turn off....
May be a dust problem that short some contact and once the dust his completely burn that go back to normal... what should i do...
did someone notice the same problem :icon_confused:
thanks
The hazard switch smoking itself was common. Just get a new one. Ford redesigned them to be less prone to doing that.
cauhcons
Mazda
Great!!! Thank you your help is really really appreciate!!!!!
superds
80
ND
Ford Bronco II
2" body. 1.5" coil spring spacers/rear block
The switch on my 99 Explorer has been doing this for a while as well. I found by jiggling the hazard switch the left blinker turns off. I've been meaning to pick one up but it hasn't been my top priority yet, thinking about buying a parts Explorer for other projects and just taking the switch from that. Adsm08, what years did they make an improved switch on?
