Just as a heads up
When you pull off the enclosure in the cab you may see a "drain" at the lower right that goes thru the firewall
I have only done Rangers with AC
This drain is for condensation from the AC Evaporator, so not sure it is on non-AC heater boxes
Its why all vehicles with AC have water dripping out by passenger front wheel, mostly in summer but in winter as well
If seen make sure its clear, can drain
As clogged drain WILL also cause window fogging
And reverse heater hoses at the firewall every 2 years, when coolant is changed, lol, if you follow that schedule
Heater cores do not have an IN or OUT pipe, coolant can flow either way
Over the years debris can come in and get stuck in a smaller passages
Coolant has a high PH and anti-corrosives, it is what prevents the corrosion of metal in the cooling system, so the circulation of coolant to all parts of the engine is what protects the metal
If a passage is blocked, no circulation, so corrosion starts
So reversing the hoses at the firewall every few years will help keep the new heater core cleaner
Once you get the old core out flip it upside down to drain it
Feel the weight of it vs the new one, that extra weight is coolant still stuck in blocked passages
Leave one heater hose off at the firewall, and raise its end up higher than core, then add more coolant to radiator
When coolant start to come out of the new core's open port, its full
Put hose back on
You should remove 1 heater hose at the firewall anytime you are refilling the cooling system, helps get all the air out of the block and heads
