- Sep 6, 2013
- 1,346
- Calgary, AB
- Ford
- Engine Type
- V8
- Engine Size
- 5.3
Carrier for a Mustang with same size axle i.e. both 8.8s would swap in, as would one from F-150, again assuming both 8.8s.Welp I should've taken the time to spin the gear the other day, that's all it would've took for me to find out what caused it! I believe all this is factory. I think at this point I'm just going to replace the whole carrier + ring gear + tone ring. The spider gears are well rounded. Maybe I'll find a junkyard unit, or maybe I'll go for yukon gears and a positraction carrier. -- on that note, can I just drop in a posi unit from a similar vintage mustang?
Along with that ring tooth being crunched off, the bolt holding the cross pin is also stripped out. I think the best course of action for me is going to be to drill out the pin itself. I think the bolt is too far recessed into the case for me to get a drill to it. I take it the pin is hardened steel? I'll have to invest in some good drill bits for this one.
Of course, I'm open to any other ideas or suggestions.
Edit: My buddy had an idea to cut a slot in the bolt and try to use a flathead to get it out. I guess it's time to buy a dremel!
I assume you mean bolt head is rounded on the cross pin bolt - I have a special ?Mac? 6 point box end long handle wrench (I think it was originally called a brake bleeder wrench) specifically for removing cross pin bolts - those bolts are put in with Ford's yellow threadlocker, so I would apply heat 1st with situation you are in.
Another solution is to weld a wrench to the bolt head - my daughter found that a fairly ingenious way to remove a couple bolts with rounded heads.
