swamprat
- Aug 12, 2007
- 3
- lexington KY
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- 2WD / 4WD
- 4WD
this is on a 1995 F150 with the M5OD. Some times the truck will shift fine. Other times I have the clutch to the floor and have to shove it to go into 1st gear. I can push the clutch pedal down about 3 inches with truck in gear before the clutch slips. Releasing the clutch it engages about 3 inches off the floor. It is not loosing any fluid. It had a new clutch put in about 2 years ago and my brother in law said that it acted the same before the new clutch. A budy of mine said he had a similar problem in his F250 and repalced the bushings in the shifter. I looked at mine and really couldnt see where they were worn. My first guess is bad slave cylinder but looking for more opinions before I drop the trany.
__________________
__________________
