2.3L ('83-'97) simple question;
Dav
26
riverview, fl
ranger xlt
, 2.9
none but it is a convertible
stock
do all 2.3 standard transmission bell housings interchange? my 95 with the automatic needs a trannie and I'm sick of messing with the auto. It will be cheaper to go to a standard
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Yes, the 2.5 is the same as well. You'll need a manual trans ECM though.
Dav
26
riverview, fl
ranger xlt
, 2.9
stock
scotts90ranger
4,367
Dayton Oregon
2.3 Turbo
I think you need one from '88-98 though, because you need the speedometer gear input in the side which went away around '98... and I say back to '88 because that was the first year of the M5OD in 4 cylinder Rangers, and I wouldn't bother with anything but an M5OD, it's a good trans...
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I believe the gear was on the tailshaft/tcase adapter which can be swapped over even If you use a VSS model trans. It's not as complicated as the automatics.
