Side mirrors
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Did Ford ever put larger folding mirrors from the factory. Similar to this...
56017
MikeG
752
central Texas
B4000
2"
235/75r15
Look like full size truck mirrors to me. Hmmm......
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
I'm trying to find some that are actual factory and not some cheap copy. I see a lot of pictures of Rangers with them, but it seems rockauto and others don't show them.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
They're called "Bright low-mount swingaway mirrors" in the Ford brochures up through 1992. So yes, they were a factory item.
They're pretty durable (unlike the little flag-style mirrors), there's good chance you can find a decent set at a wrecking yard.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
That's what I'm hoping for. Thank you.
gaz
649
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
dvdswan,
They were stock on my 87 BII; ironically, people always ask me where I sourced the Sport mirrors on the Ranger 🧐
Had to paint them black?
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Ok, so is there an interior door brace/bracket for the lower or upper arm on the mirror for support?
gaz
649
Wa, Bremerton 98310
dvdswan,
There is no interior brace, it very much just bolts on. I don't remember it the screw bosses are reinforced inside.
17,775
SW Iowa
Not really a "brace" but the skin has a reinforcement inside.
sgtsandman
Aircraft Fuel Tank Diver
12,585
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Looking at the conditions of some of the doors, I would reinforce them when mounting the mirrors. I would recommend using threaded inserts as well instead of a bolt and nut.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
So which would be better for the mirrors?
jack nuts with a plate or 12g sheet
56138
or rivet nuts in a brace/bracket about 1/8" x 1" x 6-8"
56139
I suppose I would know better once I find a set of mirrors though.
17,775
SW Iowa
I would make a plate that covers the same footprint as the mirror base on the outside of the door and put that inside the door. Then just use bolts/nuts or whatever.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Thank you for all the info.
Uncle Gump
Token Old Guy
13,442
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Exactly how I did it on my first gen... except I tack welded nuts to the flat stock and it was a bit bigger then the mirror base.
17,775
SW Iowa
It's been years since I looked at mine. Went and checked out my parts doors and there is a brace that runs top to bottom.
Starts at the top mirror bolts
Bottom mirror bracket bolts
Possibly riveted at the bottom.
