should I try cleaning MAF sensor?
bluebombersfan
New member
I'm in the middle of winter season up here in Manitoba and I think I'm only geting something like 16 mpg's or maybe 350km a tank. The funny thing is it runs perfect, very decent power and no knocking. Anyway just looking for ideas and cleaning maf sensor seems to be popular' but it's expensive part so just want to make sure this is a good idea cleaning it with electrical cleaner.
Also I think there is another sensor after the maf sensor in the air intake anyone know if you should clean this one aswell.?
Rock Auto 5% Discount Code: 248EE46702D889 Expires: October 1, 2019
bluebombersfan
New member
anyone bother cleaning there MAF sensor?
If so did it help any? I didn't want to try cleaning it then two or three weeks later have to replace it.
Directions I got:
spray down with electrical cleaner carefull not to touch wires, crossfingers, and hopefully improves lost mpg's
cr_the_machinist
New member
Dexter, Michigan
4.0L OHV
you can pick up maf cleaner at your local auto parts shop. that'll work the best. white vinigar works but i'd stick to the maf cleaner. i cleaned out my 4.0 maf and it really didn't do much. you have to be carefull as hell with those things when you pull them out of the housing.
bergz0
nj
take it out spray it up really good, let it dry then put it back in. we just did it to my cousins s10 last week... didnt help. go get a remanufactured one from you auto parts store. if you give me what kind of vehicle it is i could see what my price is.
UrbanRedneckKid
Active member
16
Cass Co, Missouri
Cleaning your MAFS is like bolting a blower on. You don't realize what kind of power is lost...
It should be done every tune-up, year, and/or time you go through sloppy mud.
Don't use electrical parts cleaner, there is special stuff made for it. MAF Sensor Cleaner.
To do it,
Key off, unplug the MAF.
Remove the 2 tamper-proof torx screws holding it in the housing.
Don't touch the ''wires'', look close you'll see the crap on the little coils.
From about 6'' away, spray liberally. I use about 1/2 a can.
Let the MAF air dry completely. Make sure it's dry.
Carefully put it back in and your done.
Make sure the key is off, there is a possibility of critical damage to the MAF and/or ECU.
bluebombersfan
New member
I guess I'll go ahead and try cleaning it, sounds to easy to make much of a difference, My CEL light isn''t on so I doubt that is the problem
97ranger4x4
New member
Sacramento
does anyone know how to get those torx screws off? I need to clean mine. One also looks like it has a cap on it?
So I tried to get the "cap" off with a knife and there is no way to get it off. It is metal. So basically how can I get to the wire part of the MAF? I took the MAF off the truck as a whole unit, and sprayed around in there. Is that all there is to it? I just saw the metal plate, no wires?
Any help would be great!
jasonl
New member
Central, PA
2.7
I have cleaned a few MAF's that helped smooth out a rough idle. It is kinda preventive maintenance. If your maf is clean abviously there won't be a differance, but if it has the slightest bit of build up on it it will definately help. I use the CRC (?) MAF cleaner from Advance auto. You need a tamper proof torx bit. It will have a hole in the center to work on the "cap" you are talking about.
ranger_tomm
New member
SE PA
helped smooth out a rough idle. It is kinda preventive maintenance. If your maf is clean abviously there won't be a differance You need a tamper proof torx bit. It will have a hole in the center to work on the "cap" you are talking about.
On my '94 Ranger, I used electronics contact cleaner, worked good, I happened to have it around. I did have to buy the tamper proof torx bit, though.
I just got my '02, and haven't done it yet....
north44
New member
Toronto, Ontario, Canada
4 liter SOHC V6
I clean mine just as preventative maintenance.
Only takes a few minutes, and it can't hurt if you do it properly.
Known issue that they can gum up over time - "an ounce of prevention is worth a pound of cure".
marlow3000
New member
Shelbyville, KY
EFI 331
just get the torx screws out with a regular torx screwdriver or some pliers or whatever and then replace them with regular screws. **** buying a bit for two little annoying ass screws
4LO 4.O
New member
Augusta,Ga
I took my Dremel with a cut off wheel and ground a slot in the head of the torx screw, now all I need is a flat head screwdriver.
97ranger4x4
New member
Sacramento
Perfect! That is a great idea. I will do that!:icon_cheers:
bluebombersfan
New member
Air Intake Cleaner
I bought some Air Intake Cleaner and got the job done today. I followed the directions spraying it right into the air intake with throttle plate wide open made me a little nervous so I just put a couple sqirts,
Engine light came on I guess it upset the balance a bit since it's flammable. Disconnected battery to reset computer all is well.
I don't think this will improve my 18mpg, I'm beginning to wonder if I have a fuel leak or something cause it runs so perfect.
slolearner
New member
Va
2.5
Cleaning MAF
A dirty MAF sensor will usually pose drivability problems. Mine ran fine at idle but wouldn't run above idle without stuttering and cutting off. I also didn't have my check engine light on which sorta ballled me too.
