- Aug 31, 2021
- 449
- Roanoke VA
- 1997 and 1999
- XLT 4x4 & B3000
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L in XLT, 3.0L in B3000
- 2WD / 4WD
- 4WD
- Tire Size
- 235/75R15 but changing to oem 265/75R15 or more likely 31x10.5
- My credo
- There are two trucks. Both are sorted. Probably selling the '99.
The air sensor on the intake is held on w/ tie wraps. It's the one about 2/3 way along the intake tube as you're looking at the engine. The little clip that holds it is broken on the sensor body that's why they did that.
It looks like it has wires that go into a harness, so absent the manual on hand I'm thinking the only way to replace this is cut the wires, splice in new sensor, which should come with pigtails, solder, shrink wrap, and put back in the wire loom. I can't think of any other way to do it without taking apart a lot of wires all wrapped (the harness).
Unless the wires unhook from the sensor but it doesn't look like it.
I believe sensor is working fine, no issues with engine. Just going over the truck and looking for things, this is minor but I'd want to set it right just as part of going over it. It is better if you can completely disconnect the intake tube completely and get it totally out of the picture.
Anyway, if anyone knows the part# that would be great otherwise I'll wait on the manuals they should tell.
Or any suggestions past what I've said as to the install.
