should i change the gears in my 89 bronco ii
jjg2596
albuquerque
2.9
i just bought a 89 bronco ii with a 4" suspension lift and a 3" body lift with 33x12.50 what are the best gears for me to use i plan on using this as a day to day truck and a weekend warrior.
mattc113
Okc, Ok
5.7
Solid Axle Swap 4x4
8"
37"
if you plan on highway driving, you might want a higher gear, i have a 3" lift with 31"s and im re-gearing to 4.10's
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
4.88 should be a good gear for that.
I have 5.13s and 35x12.50s on mine (same overall ratio) and it's just about perfect for the 2.9L.
Welcome to TRS :beer:
elpoffroad
Did you get a black one with the simulated bead lock rims??? I saw one for sale
jjg2596
albuquerque
2.9
yes its black but i dont know if it has simulated dead lock rims i think there regular rims
jjg2596
albuquerque
2.9
thanks for all the suggestions. and the warm welcome
4.0B2
151
Walls, MS
4.0 v6
i LOVE 4.56's for 33's BUT i have the 4.0..
w/ the 2.9 i'd suggest 4.88's probably. yep.
don't be scared of gear!
welcome!
mattc113
Okc, Ok
5.7
Solid Axle Swap 4x4
8"
37"
just finished swapping to 4.10's, 2.9 with 31's, now i can easily cruise down the highway at 65-70 at around 2800rpm.
trail B2
8
North Eastern Ca.
i really like my 4.10's with 33's and a 4.0.You have to decide how much time you spend going 70 or what ever figure out the RPM's you would be doing at that speed and decide where you want your RPM's to be exactly.
4.0B2
151
Walls, MS
4.0 v6
i figured it up... at 65 i'm turning about 400 more RPMs than you.. and i have 4.56's. (assuming we both have auto's.. guess its the same if we both had manuals to, i have an auto tho lol).
IMO the 400 RPMs at 65 MPH is totally worth it for the low end gain i have over 4.10's. i actually threw an 8.8 w/ 4.10's in it under my b2 one day just for curiosity, and i'm glad i went w/ 4.56's :yahoo:
but just b/c i like it, doesn't mean you would. :icon_thumby:
4.0B2
151
Walls, MS
4.0 v6
google grim jeeper calculator.. and you can figure up w/ RPMs you're at when traveling at different speeds. they have our transmissions and t/case listed.
mattc113
Okc, Ok
5.7
Solid Axle Swap 4x4
8"
37"
also it helped when i replaced my locked up fan clutch.
jjg2596
albuquerque
2.9
thanks every one i think ill go with 4.10s and give it the summer to see how it works
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
4.10 isn't even close to enough gear for those tires with a 2.9L.
