Shop wall materials?
Junk Collector
Forum Moderator
1,870
Rapid City SD
I painted the walls and ceiling with semi gloss white... think I used two coats of primer and 3 coats of paint. I wanted light to reflect off of everything and it does - even with just the crappy old 8' fluorescents it wasn't bad, now I've got a bunch of LED fixtures.
Painting the walls before I moved all my crap in was the best thing I have ever done. I would have never done it if I to move everything around to paint.
Rock Auto 5% Discount Code: 70D65189E6D8FF: January 5th, 2022
scotts90ranger
979
Dayton Oregon
2.3 Turbo
The FRP panels isn't a bad idea, the stuff is fairly cheap and resilient
Eddo Rogue
595
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Steel liner panel is great...until you try to hang something on it.
I went with painted OSB, and added FRP board to the lower 4 ft with PVC base board for a bit more protection down low. The ceiling will end up being white liner panel to reflect light and be easy, but I didn't want to deal with the downsides of having it on my walls too. The painted OSB still reflects light like steel does, but it's flat and I can mount anything in just about anyplace I want to.
That's a good thing if you ask, keeps me from attempting to hang things like shelves, which end up stacked with stuff I never use. Also tried pegboard and hangers, wasn't my thing....I'm more of a freestanding drawer box kinda guy, and preferably everything on wheels. Anyways, looks good!
Eddo Rogue
595
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
View attachment 68631View attachment 68632
Painting is actually fun when its an empty room.
ericbphoto
Overlander in development
Forum Moderator
7,125
Wellford, SC
6"
2drxploder
262
usa
ranger
347
lower
235 on 15s
I think painting is awesome, when your done. Im nearing the same stage of my shop. I know for sure I'm going osb painted on ceiling. But don't know for walls yet, definitely not drywall tho, too easily damaged.
Edit: where is frp inexpensive? $35 to 40 bux for a 4x8 sheet here
19Walt93
1,931
Canaan,NH
351
3"
235/55R16
Ok, what is FRP? A freep is a high pitched fart and I'm pretty sure that's not what you guys are talking about.
rumblecloud
270
Michigan
Ranger Splash
Stock
Stock
P235/75R15
What's the worst that could happen?
Fire retardent panel or something like that.
$30 a sheet here
2drxploder
262
usa
ranger
347
lower
235 on 15s
Thin fiberglass/plastic panels. Pretty tough easy to clean. Often used in commercial kitchens. I think its even fire resistant
Fiberglass Reinforced Plastic- proper name
rumblecloud
270
Michigan
Ranger Splash
Stock
Stock
P235/75R15
scotts90ranger
979
Dayton Oregon
2.3 Turbo
It's been a couple years since I bought any, I thought it was cheaper... but all ya need is some construction adhesive and it's wrench throwing resistant and already white... Doing strategic areas wouldn't be bad...
2drxploder
262
usa
ranger
347
lower
235 on 15s
Ya I'm debating hanging from 8' down to floor.
