- Aug 31, 2021
- Reaction score
- 974
- Location
- Roanoke VA
- 1997 and 1999
- Make / Model
- XLT 4x4 & B3000
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L in XLT, 3.0L in B3000
- Automatic
- 2WD / 4WD
- 4WD
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
I'd like to hear from people who have or have used [home] shop lifts. I don't immediately need one (though it'd sure be nice) but later I might do a car build and while it's not totally necessary I've been told it makes life a lot easier when you can raise things to a working height. Getting under it, it's not necessary that I be able to stand up under it, the stuff you do under (car) isn't all that much compared to above, plus, you can get angled seats to put you at a good working (and sitting) height. Obviously if I can raise it enough to stand under it, that's nice, but if my ceiling (joists, actually) height doesn't allow it that's ok.
Joists are at 9'10", I can put posts between them if I had to (and if I never put a ceiling) but not sure that's a great idea. Might want to put a ceiling sometime.
There is Bend-Pak probably a bunch of others. I'm pretty sure I want 2-post. Don't know if I want it removable (some you can un-bolt and out of the way) but it would be a really good feature if the performance is the same, because of the large area commited to it, it would be nice to be able to move it for other projects. Obviously cost is always an issue but I want something safe and say, capacity to lift a F150 etc as some time I might want more towing capacity than the Ranger. The other thing is boring for the hold-down bolts, that seems like I might need pro help on that.
Shop is 24' wide 32' long so I have plenty of space for it but if the removable ones are ok that seems good because then I'm not permanently committing the space.
I'm not posting ones I looked at so far so as to not prejudice anything. And it's not totally dependent on the project car, it'd be awfully nice to be able to lift the trucks for things like brake work, oil change, etc.
