Shifting issue
repairedit
Lakeside, Or
2.9l
98 XLT Ranger 4x4 4.0L
I have just replaced the clutch disc, pressure plate, slave cylinder, clutch master cylinder and pilot bearing on my 4x4 pickup.
did not take apart originally so i cant confirm presence of flywheel spacer. could the lack of spacer cause no shift ?
Not sure how this works in, but when i unbolt transfer case from transmission the truck will shift when running. Bolt transfer case back up and no chance of shifting to any gear.
clutch peddle feels good appears to have about 3/4" to 7/8" travel on throw-out bearing.
Any ideas I'm open to them..
Thanks
superj
3,474
corpus christi, texas
ranger edge
182 ci of tire shredding power
2, so far
235s
drives a stick shift ranger
the clutch disc is not accidentally in backwards?
just wondering as i have done it before
repairedit
Lakeside, Or
2.9l
already checked that and no its all together correctly.
SenorNoob
TRS 25th Anniversary
1,015
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Truck parked engine off. Can you have someone hold the clutch pedal down while you try to turn the output shaft with transmission in gear? That would tell you if the clutch is releasing.
No members online now.
Rick W
October Truck of The Month
25th Anniversary Merch
