- Sep 12, 2024
- 3
- West Virginia
- Ranger 2WD
'02 Ranger 2WD 4.0L Ext Cab XLT 150K mi - Have a couple of annoying issues I’m working through, I’ll start with the biggest pain in the arse. I cannot shift out of park unless I put the ignition switch in the On position and move the shifter slightly out of Park with the brake pedal depressed, then start the truck. If I move the shifter to reverse/drive all is good, if I move it back to Park, it locks again. It seems to lock in Park only after the key returns to On from Start.
The shift lock solenoid and the brake pedal circuit appear to be working. I have to depress the brake pedal to move it out of Park with the ignition in the On position. I pulled the lock cylinder out and dissembled, cleaned, lubricated, and reinstalled. No fix. Can anyone point me in the right direction?
Next issues are intermittent Cruise Control and and intermittent Air Bag light (steering column harness?) and intermittent ABS light, but those are for later posts. One thing at a time.
