Shift kit for 5R55E (original thread said Clutch kit)
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
973
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
I'm think I'm getting to the end of fixes for the '97. When I get cruise buttons in, assuming they work, then the only other thing I know about is the retractable cover for the back doesn't retract easily. You can pull it out and get it to roll back up but it's dodgy, you have to fiddle with it. I think, that it was most likely never used so setting there 25 years it's just balky. This is pretty minor and I don't think I'd really use it either. I suppose it could help to hide things from prying eyes, but you can't really see in the tinted windows anyway.
So once I'm satisfied all is good as to the stock truck then it is time to think about upgrades. The 2 things I'm thinking about are the hubs (first), and I think it was mentioned I'd want to put in a clutch kit for the trans. Am I replacing stock with stock, or am I upgrading past stock, and what does it do for me? Truck shifts ok, I don't think it's as smooth as the '99 but don't know if that has anything to do w/ clutch. '97 has 60k less miles (125k vs 185k for the '99) so you'd think it'd be the other way around but 99 could have had work done who knows.
Is it hard to do? I mean, I can look in the manual, it should have instructions how-to, I'm just asking in a general sense how hard it is.
And what do I want for parts, could someone please post an example?
Thanks.
superj
2,574
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
A clutch is a fairly easy change. Its just unbolt and replace, than bolt back together in the same way.
The hardest part for me has always been getting the shifter in and out of the hole in the floor without tearing up the sheet metal. There is probably some pro easy way but i dont know it.
00t444e
217
Southern OH
Ranger ext cab
Go with a Luk clutch for the replacement.
James Morse
973
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
OK, thanks. This is 5R55E so I shouldn't be going through the floor.... I think.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
5r55e is an automatic, it doesn't use a clutch. It will have a torque converter.
James Morse
973
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
Ah. Then back when this was suggested to me, obviously I somehow must have not been clear about the tranny.
I'll check shop manual on the auto and see if there's anything about it I'd want to check And open to suggestions of course.
Tenper616
8
Florida
Mazda b2500
2.5 (4 Cylinder)
A clutch kit would go inside the trans as an automatic trans is driven by internal clutch packs and not gears, so you would have to remove the pump input shaft and drum, then replace all the clutch packs and reassemble, not hard to do per se however if you've never done one it can be confusing
superj
2,574
ranger edge
none
none
235s
And probably easy to ruin the transmission if the pump is not seated on the splines properly, right?
Tenper616
8
Florida
Mazda b2500
2.5 (4 Cylinder)
Very much so a transmission job is best done very slowly and carfully in a very clean spot
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Don't mess with an auto besides fluid & filter until it starts shitting the bed. No sense in it. The exception being a shift kit. The wearable parts in an automatic (if it's been maintained) should last 250k.
lil_Blue_Ford
6,129
Butler, PA, USSA
4.9L
Yup, clutch is only for a manual. Well, there are “clutches” and stuff in an auto, but never mind that. For an auto, I highly recommend a shift kit and one piece gasket for the valve body.
