setting timing on 2.9 v6
stamina
34
Wilmington, NC
4” suspension
265/75/r16
built her in a storage unit
i am going to set the timing to 12° as stated by another person on this forum, is it necessary to put the #1 piston on tdc to set timing? it doesn’t say it on the hood sticker but it does in the haynes manual. do i need to do this? and if so why? also, when setting timing do i do it with the accessories on? radio, ac, etc?
8,370
If the engine is currently running then you just need to do a few things to set base spark timing
Clean off the "pulley" and pointer so you can clearly see the marks
If you put paint on the tip of a rag and then wipe the marks the paint will stay in the marks making them easier to see
Find the SPOUT connector, on a 2.9l its should be on passenger side of lower intake near distributor
Warm up the engine
Turn off engine
Loosen distributor holding bolt, but just enough so you can turn distributor
Hook up timing light
Unhook SPOUT connector
Start engine
Turn distributor until #1 spark is happening at 12deg BTDC
Tighten distributor
Recheck timing
turn off engine
Reconnect SPOUT connector
Start engine
Should see spark at about 20deg BTDC now
AC should be OFF, as every time it cycles on timing will be harder to read, won't hurt just an irritant
Cab electric devices can be on or off won't matter
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Warm up the engine
Turn off engine
Start engine
Tighten distributor
Recheck timing
turn off engine
Start engine
@RonD can you frame thos or make it Google's banner?
stamina
34
Wilmington, NC
4” suspension
265/75/r16
Warm up the engine
Turn off engine
Start engine
Tighten distributor
Recheck timing
turn off engine
Start engine
you’re awesome bro
