setting axle
masterbrenden
twin peaks,C.A.
ford/ford
3.0l v6/4.0l v6
hi i am setting up my 7.5" axle with traction-loc and my moms boyfreind has a question...
does the final shims need to be cut out of one peice rather than having a bunch of shims in there, he ask because he is wondering how they stay were they are without moving around and falling out?
merace19
Which shims you talking about?
masterbrenden
twin peaks,C.A.
ford/ford
3.0l v6/4.0l v6
the shims in the pumkin to move the differential
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Shims are shims. You don't have to figure out what you need and then have a one piece shim made up. They won't move around, they are held in place by the bearing caps and the pressure from the side bearing preload. The carrier should not fit into the housing loosely.
I'm guessing this is the first time you've played around with setting up a differential?
merace19
What he said^^^^^. there are other shims in there also. The ones on the pinion.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
If you are just replacing an open carrier with a trac lock carrier, you won't have to change pinion depth. Most of the time backlash stays in spec as well, but backlash is all you will have to adjust if anything.
merace19
Yeap.^^^^ For some reason the 7.5 is a dream when it comes to swapping carriers and gears.
I use to swap back and forth 3.27 gears to 4.10 gears all the time in a race car rear instead of changing complete axle housings. I would just run a big zip tie though the carrier and the shims so not to mess them up where they go. Pattern was always spot on. I may have just been lucky though.
masterbrenden
twin peaks,C.A.
ford/ford
3.0l v6/4.0l v6
we got it all set up my moms boy friend just thought i should ask because we pulled one big shim out of each side
he is used to setting spools in sprint cars with gm rear ends and we were changing gears carrier all of it every bearing,seal,race, brakes,the only thing we did not change was axle shafts
the previous owner set it up "tweaker style" it was a non abs carrier in an abs truck and had about 1/16 to 1/8 inch of play in the carrier 3.73 gear were 4.10s belonged and thiss was because it was what he could find
merace19
1/8 play on the carrier? That is crazy. Surprised it didn't snap the bearing caps off.
