2.3L ('83-'97) Set timing without cam sensor
Chapap
672
NW Florida
Ford Ranger XLT
2.3
1.5” till I get these springs replaced
225-70-R14
Everything I’ve read says that it doesn’t matter if you have the intake or exhaust stroke identified because the valves determine that. It made sense to me but I never felt good about it. I finally realized why. How do the injectors know when to fire if you don’t have a cam sensor? If you’re off by half a cycle, they would be injecting on the power stroke instead of intake stroke… right? What would be symptoms of this?
scotts90ranger
4,328
Dayton Oregon
2.3 Turbo
On a batch fire system they calculate the amount of fuel needed to run and both fuel injectors (two pairs, 1 & 4 and 2 & 3 since they share TDC on a 4 cylinder, one on compression and one on exhaust stroke) fire at the same time. I don't remember how the intake valve timing works out but it does... It's slightly less efficient to run on batch fire but it works fine, especially for ignition...
Chapap
672
NW Florida
Ford Ranger XLT
2.3
225-70-R14
Interesting. I never would have thought that was done, but I guess it’s the only way to do it without a cam sensor. Since there’s half a dose of gas in the intake during the combustion stroke, could a leaky intake valve cause odd problems?
8,369
With a distributor sequential fuel injection is easy because a distributor IS a cam sensor
With distributorless systems sequential injection is still possible, after warm up, using power and efficiency from crank speed and O2 sensors
Computer has LITERALLY a 50/50 chance of getting it right just by guessing, lol, but if injector opens just when intake valve opens crank speed/power will be better and O2 will show better burn, vs slightly leaner if injector timing was on exhaust TDC, because more fuel stuck to intake/port walls
And that takes all of 2 seconds to do
