Service/Parts Recommendations
MastuhWaffles
11/2014 OTOTM Winner
76
Texas
4.0L SOHC
I need more sleep.
my 2005 2wd has an elongated hole for the driver side lower control arm, forward position. it's from the factory that way.
there is nothing special about that bolt.
don't remember if the pass side had the adjustment hole.
See like he pointed to a lower control bolt but it looks like just a bolt to me.
MaicoDoug
467
Texas
Ranger FX4 LVL2
2 inches in the back, not enough in the front
32x11.5x15
The lower picture shows the square plates. So I believe that your mechanic is not 100% believing you & of what he's looking at. They both operate the exact same, square end plate or round. Rolling around on their sides to lift the upper A arm. If this is not completely clear, I would back off & find someone who is a bit more literate on the subject. This is a front end, there should be no confusion.
19Walt93
4,802
Canaan,NH
351
3"
235/55R16
So I mentioned that and they said thats not it but mine are the factory ones with the square blocks.
Those square blocks are replaced with the round excentrics when adjustment is needed. Try to find a more experienced alignment tech.
MastuhWaffles
76
Texas
4.0L SOHC
I need more sleep.
Yes which is why I said I don't think there is an adjustment on stock which makes me wonder how they adjusted the one side at all. I may just do the cam swap myself.
19Walt93
4,802
Canaan,NH
351
3"
235/55R16
It's possible they removed and repositioned the square blocks but it's unlikely they got the caster and camber to the preferred setting that way. If it's not set to preferred, it's not aligned properly.
pjtoledo
3,537
Toledo Ohio
Fords
3.0 2.3
the square blocks come with many different hole locations. the correct one was used at the factory to lock in the alignment.
I have also seen oval shaped plates that looked factory but can't verify them.
and of course the round aftermarket ones.
Rick W
October Truck of The Month
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
