- Aug 19, 2001
- 580
- So. Calif (SFV)
- Bronco II
- Engine Type
- 2.9 V6
- Engine Size
- 2.9L V6
- 2WD / 4WD
- 4WD
- Tire Size
- 35x12.50R15
Would this happen to be a speed sensor?
Are they now back on the transmission instead of going through the axle ABS sensor?
If so, anyone happen to know any details on it?
Like...
1.
Will it fit in the speedo port of an older transmission or 4WD T-case?
2.
Does it use original-style speedo gears? Or is it a magnetic (hall-effect) thing with a tone ring inside around the output shaft?
3.
Would this again allow for correction of your speedometer by simply matching the axle gear ratio to a larger size tire?
Like...
1.
2.
3.
