Psychopete
- Aug 10, 2007
- 29
- FW, IN
A machine shop here got my lower intake spotless. But it will eventually get dirty again.
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
NO, it does not, never has, never will. If it did, we wouldn't have used it to de-soot aluminum wing members on KC-135s. Or fuselage skin. Or any of the THOUSANDS of parts on a jet.+2 on the Simple Green. Awesome stuff AND non-toxic to boot!
The only hitch is, Simple Green ... can actually attack aluminum. This can cause the parts to become brittle and eventually fail.
I've used Simple Green on tons of aluminum stuff, I've never heard or seen this. Actually it was recommended by most of the boaters I knew, and I know there's a lot of aluminum on their stuff.NO, it does not, never has, never will. If it did, we wouldn't have used it to de-soot aluminum wing members on KC-135s. Or fuselage skin. Or any of the THOUSANDS of parts on a jet.
Every bit of it - ALUMINUM.
Where does this blatant CRAP get its start?
Boaters (like me), use & recommend Simple Green because it is 100% biodegradable, & safe to use around wildlife.I've used Simple Green on tons of aluminum stuff, I've never heard or seen this. Actually it was recommended by most of the boaters I knew, and I know there's a lot of aluminum on their stuff.
Jesus chill out man. I was trying to give advice, not advocate rudeness.Where does this blatant CRAP get its start?
apperantly simple green started it.Where does this blatant CRAP get its start?
I didn't call your post crap. I called the idea crap, because it is.Jesus chill out man. I was trying to give advice, not advocate rudeness.
As far as the bit about aluminum goes, how about this snippet direct from Simple Green's website? URL: http://www.simplegreen.com/solutions_faqs.php?search_query=aluminum
Aluminum - Is it safe to use Simple Green® on aluminum?
When used with caution and according to the instructions, Simple Green All-Purpose Cleaner has been safely and successfully used to clean aluminum. Simple Green All-Purpose Cleaner, Crystal Simple Green® Cleaner/Degreaser, Simple Green Pressure Washer Concentrates, and Pro Series™ Simple Green® Automotive Cleaner have been used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green All-Purpose Cleaner can accelerate the corrosion process. Therefore, contact times for unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green® product residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation.
Notice I didn't say, "OMG DON'T USE SIMPLE GREEN ON ALUMINUM!!!11! IT WILL DESTROY YOUR VALVE COVERS!!" I've successfully used it on aluminum with no trouble bit I also was using a lot of water to rinse the area to help me check progress.
I don't mean to sound rude myself but referring to my post as crap isn't good manners.
