- Jul 29, 2023
- 408
- BC Canada
- XLS Bronco II
So I use my BroncLander for overlanding and Ive found that using the starter battery for charging batteries and phone while I'm camping can be a bad thing if I don't remember to run the vehicle once a day.
The battery in it is a tiny little thing obviously way too small for the application. So what I'd like to do is install a way bigger battery platform that holds 2 batteries and add a lithium 100ah. And then on top of that, have a 50 watt panel on the roof charging the house battery independently from the starter battery and alternator system.
There's also a way to tie in the house battery to charge off the alternator once the main starter battery is full. And while not totally necessary, it would be smart to do all at the same time and just be done with it, and then wire up a nice little panel box with a decent inverter and fuse panel.
By next season I definitely want the Bronco to be a bit more organized for camping and fishing. A roof basket of some sort is a definite must. I thought about a sealed cargo container up top, because it would keep things dry and sit to one side allowing my kayak to live on the other side, but I may just design a basket that has provisions for the kayak to one side.
If I was any taller I couldn't make this all work without a micro camper trailer or something, but I just fit if I'm at a bit of an angle, which is great for the overlanding I like to do.
Currently I'm searching for some solar panels. I've thought of flexible ones, rigid ones. Still undecided. If I could find 2 30 watt panels that were the size of racing stripes, I might put them on my hood and just glue them down with silicone.
youtube.com
Solar Panels on a Bronco2?
