Junk Collector
Truck of Month
- Mar 4, 2008
- 5,431
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
Need some input. I am going to SAS my 2 door Explorer in the near future. I will be using a full width D44 from a '76 F150 and a full width 9". Will be running 36" TSLs...that is the biggest tire I want to run.
I will probably need about 4-6" of lift to clear the tires. I am planning on losing a lot of sheet metal around the wheel wells. Totally fine with that, would rather have a low center of gravity since this will be primarily a rock crawler rig. Rear will just be leaf springs.
Front suspension is what I really need input on. I already have a SAS rig with factory 70's radius arms and coil springs. It works fine but has some durability issues (bushings mainly.) I want something better that I don't have to rebuild every year. So naturally I am leaning towards a link setup of some sort and coilovers/air shocks/struts/etc instead of coil springs:
1: Coilovers? ORIs? Nitro shocks? What and why?
2: Links - what style? 3 link? 4 Link? Radius arms/long arms w/ track bar?
Clearing the engine crossmember with the front diff is a major concern of mine. I am about 95% sure I will cut it out and reinforce the frame so that I can keep the suspension height lower. Having that out of the way may make a 4 link easier to do.
