sas dana 44
FordRanger89
05/2013 OTOTM Winner
2.9l
In essence yes. I bought one from a guy who sent them his stocker then sold it to me. So no it is basically an EB 5-760x U-joint passeger shaft.
Your wheels look tall and narrow, just like I like em, what size is your tire/wheel combo?
well they are kind of small. 33x11.5 r 16
I am going to run 35 or 36 inch tires from now on. I had just bought those tires before I did the sas.
RangerDW
FORD
Near Future
Nice job on your SAS. I am about to start on one my self. I just finished the rear with a upgraded 8.8 w/disc out of a 2000 Explorer. I have a D44 out of a 79 F150 and deaver coil springs.I do plan on shorting it also. How is steering radius compaired to the stock set up?
foxracing5491
clinton,ma
302
i installed a full spool in my d44 sas and have that same problem. it was worse in snow when my back tire would spin do to open diff. your rear is getin less traction then you front or vise versus causing the suspension to travel. mine is only slight, so im goin to just deal with it until i get the trac lok i just ordered. ill be trying to stuff hd d44 shafts in with the sAme size u-joints as a d60. and save your comments the 5-86 are a 1350 joint and are replaceable with the d60 5-282 which are now the 5-447 or 5-799
scooter
October OTOTM Winner
50
N.W. Oklahoma
5.0L
Ummmmm. Ill save my "Told you so" till u give it a whirll. ( u-joint wont fit through the hole in the knuckle, but im not gonna tell you that, idiot)
Todd S.
foxracing5491
clinton,ma
302
every one says that but i just replaced a sheared 5-297 with a 760 and the hole in the knuckle was about 5 inches wide, i dont know if its because im runnin an 8 lug, the only problem i see is clearance issue with the threads of the lower ball joint
foxracing5491
clinton,ma
302
i may be wrong but im goin to try like hell to get them in there. i may just shave the outer of the ears and make an internal full clip fit. itll still be stronger then my bent to shit ears on my stock shaft until i can get some chromos or just final talk the guy that im selling his d60 for to let me have it.
foxracing5491
clinton,ma
302
oops only saw first page, didnt know he already found the problem, i sumtimes put my 2 cent in even if im wrong. but least i try. and im not an idiot, just not crazy educated about this stuff. i research as i go and ive only been building my truck for a year and a half and ive already got pretty far.
cdawall
U.S. Military - Active
5
Ellsworth AFB
4.0L V6
Can you not see the edit button on posts? You don't have to make a new post every 15 minutes.
scooter
50
N.W. Oklahoma
5.0L
You CAN NOT run D-60 u-joints in a 44 shaft.
You CAN NOT run D-60 u-joints in a 44 knuckle. IT WILL NOT FIT, thats a fact.
Research before you spout off. You think your the first guy to think of that?????
Noooooo your not, okay....
If you want to run a 60, buy one. If you wanna run a 60/44 hybrid, good luck with that....
I called you an idiot because you posted with attitude. Dont post "i dont care what you say", even though you have never tried or even measured to see if it will fit, and not expect me to tell you your an idiot.
Todd S.
Bennybooster
EMT / Paramedic
37
Medford, Oregon.
Todd S.
I tried to rep ya but it wouldn't let me
FordRanger89
2.9l
Haha i love the conversations that go on this thread!! We are having way to much fun.
The steering radius is pretty close, maybe ever better. The only problem I have found is that my tires rub against my radius arms when I am turned all the way. You may want to invest in some offset wheels or wheel spacers.:icon_thumby:
Here are some new pictures!!!
scooter
50
N.W. Oklahoma
5.0L
Mine only rubbed when i was turning and in a tire "scrubbing" situation. (if that makes any sence) , like off camber or rock crawling. If i was street driving, it wouldnt rub.
Todd S.
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
Is that your license plate number on your window???
And stock radius arms suck.
