- Feb 10, 2021
- Reaction score
- 0
- Location
- Glendale
- Make / Model
- Ford Ranger XLT
- Engine Type
- 3.0 V6
- Automatic
- 2WD / 4WD
- 2WD
Hello
So as my luck would have it I have a weird ordeal. Let me rewind and give a bit of history on the rig. 2003 Ford Ranger 3.0L Vulcan V6 Flex fuel with around 120K on the clock. The engine was neglected and retired early. The last shop it went to said it needed an engine. It initially went in for a Check engine light staying on Cylinder 1 Misfire. So that said it has had an engine replacement. I installed new coil, plugs, wires, cam syncronizer and IAC all Motorcraft parts. I broke the engine in and on the rigs first road test I am stuck again with the same check engine light cylinder 1 misfire. The engine ran a little rough on initial start up I got the cam syncronizer dialed in at 38* as the service literature says it smoothed out a little bit. The test drive went fair but the check engine light was really discerning. I dont know if that running rough is part of the relearn process or what. Now I made sure the plug wires were on the right coil tower and going to the right plugs. I am kinda lost with this one. Literally all that money spent on the engine and it runs the same as the old one did. Fuel system has been kept up new fuel, new filter and fuel dampener. I am curious as to what any thoughts on this might be...? Could it be the PCM...? That is the only variable left I think. Any insight from the Ford Ranger gurus would be greatly appreciated. Thank you for your time.
