hilawfresh
- Apr 9, 2022
- 0
- Antioch CA
- Ranger
Hi everyone. So I pulled out my heads today and noticed cylinder 1 bore is more rusted than others. You could also see it on the head. Is there a reason this happened?
Also I removed the heads because of mixture of oil and coolant when I drained the oil pan. Is the head gasket the only culprit for this?
One last thing, is there a way to drain all the coolant in the engine? I removed all the hoses, top & bottom, (except water pump) but coolant is still sitting. I can't find any drain plug anywhere in the engine.
Thanks
Thanks
