Rust on cylinder 1 bore
hilawfresh
Antioch CA
Hi everyone. So I pulled out my heads today and noticed cylinder 1 bore is more rusted than others. You could also see it on the head. Is there a reason this happened?
Also I removed the heads because of mixture of oil and coolant when I drained the oil pan. Is the head gasket the only culprit for this?
One last thing, is there a way to drain all the coolant in the engine? I removed all the hoses, top & bottom, (except water pump) but coolant is still sitting. I can't find any drain plug anywhere in the engine.
Thanks
8,367
Looks like #1 was steam cleaned so had a cracked head or blown head gasket
So rust after sitting
Just clean it
No drain on the blocks any more
If you want all the coolant out put a small hose(like longer rubber vacuum hose) down block coolant passage at lower rear(do each side) and siphon out the remaining coolant
When I cleaned inside passages of V6 block last time, I move the vehicle outside, took off the water pump and use the small hose to flush out the block
Also used a long screwdriver down all the holes to break up crud that had settled at the bottom of block, ALOT of crap came out
hilawfresh
Antioch CA
Thanks Ron! You have been a great help to me. Will tackle it this coming week.
8,367
Looking at the picture of the head, it looks like there may be a crack between valve seats in #1, but hard to tell
55trucker
183
Oshawa, Ontario
mild
Send the heads to a machine shop, have them tanked & then pressure tested.
After tanking they will quite clean.
