- Apr 7, 2019
- 0
- Springfield, OR
- Ford Ranger 4x4
- Engine Size
- 3.0
- 2WD / 4WD
- 4WD
- Total Lift
- 8"
- Tire Size
- 37-12.50R15
My 99 3.0 manual 4x4 is doing the ereader rough cold start. I know someone will jump on me for not searching but truth is I've been fighting this for months and have read every thread I can find here and on other sites that even remotely looks plausible. That being said.
Truck is a 99 3.0 non flex with a manual and 4x4. It has roughly 250000 miles on it.
When i go to start it in the morning (temp doesn't seem to matter) It will die 4 times like clockwork before it will idle. Idles rough for a few minutes and then runs great. If it has been sitting about an hour this process is reapeated. If less time then there are no issues.
I've pulled the codes a dozen time with a good code puller and never have any useful codes. Usually no codes at all. Also no check engine light ever. I've replaced all gaskets from the head gaskets up. Verified no vacuum leaks, replaced all three o2 sensors, replaced IACV, tested the egr system cleaned the maf and all sensors, changed fuel filter and oil, new battery and alternator and ran a can of seafoam.
Any ideas?
Any ideas?
