- Aug 13, 2021
- 8
- Colorado
- Ranger
1984 2.8 3spd with the duraspark conversion. Engine sounds like it’s missing on a cylinder. Heavy vibration at idle in gear with the brake off. There is a puff of blue smoke on start up, and a small puff when I accelerate after idling. Definitely audible valve noise.
I have checked the spark plugs and they all look about even. No oil, gas or excessive burning etc. when I did the conversion the new distributor and ignition system added a ton of power, but didn’t fix the rough idle problem which existed with the old system as well. Once the engine revs up it seems pretty smooth and has adequate power.
All the ignition parts are new.
Could out of adjustment valves caused this problem or am I better off looking deeper, like a leak down and compression test? I definitely don’t have the time for a head gasket rebuild at the moment, and I have already done the glove test on the radiator which showed no obvious head gasket leaks from there.
Any advice is appreciated!
