Running rich, need guidance.
Well-known member
1,364
Look at the VIN, in windshield corner or drivers door label
8th digit is engine type/size
U = 3.0l gas only
V = 3.0l Flex Fuel
The computer is different and so are the injectors, these must match or you will get lean or rich codes, depending on the mismatch
Flex computer with gas only injectors = Lean codes
Gas only computer with flex injectors = Rich codes
VIN will tell you which computer you have, unless you think its been swapped
I think only the 1999/2000 Rangers had the fuel sensors
Rock Auto 5% Discount Code: CFB3B5F7F32B37 Expires: March 30, 2020
Well-known member
1,364
Then you have a gas only 3.0l and computer, and no fuel sensor, so you should be using the smaller injector size, flex fuel injectors would cause Rich codes
Injectors are not like Jets on a carburetor, so larger injectors won't give more power, it will just cause Rich codes
